Import Steelwork models ?
Does anyone import steelwork models from other structural design programs and then use Archicad to build the building around them ?
I work for a building contractor and we're currently researching the use of 3D models as both a marketing also a scheduling tool etc. I know I can build a steel frame within Archicad but it won't be as precise as the steelwork contractor can do it on his own software. I often see nice 3D isometric drawings of steelwork, it would be nice just to import them and build around.
Anyone know if any steelwork software can export into a 3D format recognised by Archicad and does anyone work this way?
5 REPLIES 5
__archiben
hi jus
check out the archicad solutions/structural page here...
http://www.graphisoft.com/products/archicad/solutions/structural.html
there is plenty of information regarding archicad's structural connections . . . along with import/export add-ons for each structural solution.
cheers!
~/archiben
b e n f r o s t
Djordje
IFC is the way to go.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks guys.
Research and communication with our steelwork contractors I think...
Does anyone know how a *ArchiCAD List Setup File* works ? A steelwork contractor has exported a steel frame from Tekla Structures into what I thought was an XML file, however, the extension is *.LIS and is recognised by PC as an ArchiCAD List Setup File.
Aaron Bourgoin
The LIS file would be an irrelevant format in this case LIS is an internal file structure for producing schedules (sometimes called a List Scheme).
The Tekla teammember needs to export an XML file - you need to locate a translator and the manual found on this page:
http://www.graphisoft.com/support/archicad/downloads/AC-TS/
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
