Greetings. I believe Archicad and Vectorworks are related software. Is there any way to obtain and load Vectorworks Landmark default plant library? Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
The only relation is that both companies belong to the Nemetschek Group. But there is further relation than that.
You best bet would probably be to save those plants you need from Vectorworks as DWG or IFC or some other format that ARCHICAD can read. But I don't think you will just be able to load a Vectorworks library (which is normally stored in a Vectorworks project file) into ARCHICAD.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
Thank you Laszlo - is there any add-on or library that you know of or could recommend to make Archicad more useful in landscape architecture? Vectorworks Landmark is a good example of landscape architecture software. Scott
