2 weeks ago
- last edited
2 weeks ago
Dear community,
I did a terrain with Civil. And this terrain I exported as an IFC file. I have to import IFC into Archicad. But I need to extrapolate the quantities of the volume of the terrain. Because when I import the IFC file, I can't read these values. How do I do it?
Thank you to all for the answer.
Solved! Go to Solution.
2 weeks ago
What if you convert it to Morph?
Schedules can report the volumes of Morph elements.
2 weeks ago
When you import the IFC terrain, will it generate a 3D geometry? Will it become an Object (Library Part) or a Morph?
2 weeks ago
when I import IFC, it becomes an object with its own geometry
2 weeks ago
2 weeks ago
I must convert it to Morph, and then Check Solidity, because it has a free-standing edge.
