Importing 3D dwg(AutoC2000) to AC 9
hello, I m a beginer, i m having problem when importing from 3Ddwg(autoC200) to ArchiCad 9,
before that a have sucsses with default Translator.
then sometimes I try to import other 3Ddwg file again(Acad2000) into ArchiCad 9, and its just show nothing or the file become broken when i hint (Ctrl+3), trully this problem just make me headick
Please any one give me the solution, where is the wrong thing come from?, (is the Dwg, or the Archicad).
Thankz Before and All the respect for the any answer
1 REPLY 1
To successfully import 3D information into Archicad you must open the file (either DWG, DXF or 3ds) as a library object. This will retain the 3D information from Autocad file. It will however group all the 3D information into one object.
DWG is acad file !
PLN - archicad file
Read archicad help, u will see it when u press F1 in archicad. U have a lot of gaps in your knowlegde so plz try to learn basic stuff FIRST.
Now i can write u step by step tutorial for import, but nothing will be accomplish cos ur fundation is missing.
SO GET AS FAST AS U CAN ARCHICAD BOOK, READ ARCHICAD HELP ETC
