Importing Microsoft Excel documents in Plotmaker
You used to be able to import Microsoft Excel documents (door schedules, area schedules etc.) directly into Plotmaker.
This is not the case with Plotmaker for ArchiCAD 8.1.
Is there a way around this?
4 Replies 4
tsturm
Dear Andy
Read my post on this topic in the Data Exchange and Information Sharing section.
http://www.graphisoft.com/community/archicad-talk/viewtopic.php?t=1314
This process should help you out.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
This is a bit of a complex issue (much has been written on it) which is also platform dependent. The short answer is OLE works in Windows but not in OSX (unless MS has improved matters with Office 2004). There are a variety of issues and work-arounds which I will not go into here. We are all hoping for some improvement in this area (like PDF import to PM). It has always been harder than it should be to get text and tables into PlotMaker.
BTW. Please add your computer info to your signature line. Many questions are hard or impossible to answer without it.
Thanks this works
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
"Does OLE work with OSX and ArchiCAD 8.1?"
No - not in the way it worked with OS 9 and AC 7.
There are alternatives however..
See GSKB (FAQ's) Rec#'s
700
666
422
352
Via: http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
