Importing texture files with 3ds models
I read on site that I can import 3ds files using 3dstudio add-on. I downloaded it, and imported object in AC but everything is grey. I don't have any texture on the model, but i got a folder with textures for that object. My question is if anybody knows how to import those textures with 3ds file?
12 REPLIES 12
I know that, but the bigger problem is that there's no many objects which has options for changing materials. If there is i am satisfied, i can change them manualy. There is a lot of objects where I can modify the whole composition in one material. Ok than, i see that the problem isn't in me. Is it too much if I ask you for some sites for those objects except archibase and archive3d?
Stress Co_
Check the links in THIS post.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Sorry to post this message so much time after the previous one, but I have the exactly same problem, any solution found since this time?
Also sorry for my bad english!..
