Michael
Interactive Schedule Room Material Codes
question : Is it possible for the Interactive Schedule to list the Room Material Codes
These codes are found in the Zone Setting Selection menu
Say I input EP (Epoxy Paint) in the wall material listing in the zone lists menu
Now when I "calculate" A Room Finish Schedule, I would like to report that Room 101 has an EP (Epoxy Paint) wall onto the schedule.
Unable to locate this field callled room material code
.....perhaps this is a bit more clear .......thanks for your thoughts
Michael |:-)
AC 4.5 - 19 Build 3003 Full USA
Mac OSX 10.10
TomWaltz
I'm not sure I understand what you're asking.
Tom Waltz
Yes it can; just make sure you select the 'additional parameters' (Element Schedule Schemes) and choose the zone object you are using then select the actual values ie room finish and it will appear in the schedule list.
Regs
mark
