koncs
Issue with Exporting Text from Archicad to AutoCAD – Text Gets Scrambled
Hi everyone,
I'm having an issue when exporting files from Archicad to AutoCAD. After opening the exported drawing in AutoCAD, the text appears scrambled – its position  changes (I use ISOCPEUR font). This can cause significant readability problems in the documentation.
Has anyone encountered this issue before? Is there a specific setting in the Translator that needs to be adjusted to ensure the text is transferred correctly? What are the best practices for exporting to avoid these errors?
Thanks in advance for any advice!
3 Replies 3
CosminF
You could try changing/ checking the anchor point of the text box.
If it is set to one corner, maybe autocad will asume the anchor point is the text centre and this is why you have this offset.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
koncs
Ok, this method works for some texts, but there's still an issue—the line spacing (including enters and spaces) is larger than in Archicad. This would require recreating the texts from scratch, with separate text elements for each entry, for example, in a legend where there are gaps between texts.
koncs
