2011-09-15 10:29 PM
2011-09-16 12:42 AM
2011-09-16 02:43 PM
2011-09-16 06:33 PM
2011-09-16 08:43 PM
2011-09-16 09:32 PM
2011-09-17 09:33 AM
2011-09-17 01:57 PM
2011-09-23 05:12 PM
2011-10-07 08:39 AM
JaredBanks wrote:We always use the method described by TurboGlider because ID is almost always "used/occupied" according to national rules...ex F12x20HXXXXX (or worse...
Another solution is to filter by ID. This is how I typically do it. Change the ID of all existing windows to EXISTING. Then exclude them from the schedule criteria. Simple, fast, easy. You can also exclude empty openings in the same manner (label them EMPTY, for instance).
Or if you can, filter by layer, so only include windows/doors on the walls.new layer (or however you label new construction vs. existing construction layers).
