Listing items own length instead of the sum of all (ac 13)?
Hi!
I have alot of beam in my slab. I want to list all those beams in a way like
ID, HEIGHT, WITH, LENGTH, QUANTITY
If I got 3 beams that have same H, W & L, then I got Q = 3, but my L is objects L * 3 ??
I want to show the length of a single object, not the sum of all, is there a way to do this?
Yes it is: ucheck the "Show uniform items as a single entry" setting!
In this way if you have 5 equal beams you get 5 equal items in the schedule.
But that's not what I want.
In schedule you have a parameter "Quantity", if you use this then it will show how many items there is.
If I have checked "Show uniform....", then I got one row for each type of beam and the quantity correct (4 in this case), but the beamlength * 4. In my opinion, this is wrong. It should display the length of 1 single item, not the sum of them. Then maybe give us an parameter "Sum lenght".
If it is unchecked, then I got 4 rows with identical parameters and quantity 1 piece on each row?!??
If I want to make an order of my beams. I will present my parameters :
Type, classification, size, length (of single item), quantity...
