But that's not what I want.
In schedule you have a parameter "Quantity", if you use this then it will show how many items there is.
If I have checked "Show uniform....", then I got one row for each type of beam and the quantity correct (4 in this case), but the beamlength * 4. In my opinion, this is wrong. It should display the length of 1 single item, not the sum of them. Then maybe give us an parameter "Sum lenght".
If it is unchecked, then I got 4 rows with identical parameters and quantity 1 piece on each row?!??
If I want to make an order of my beams. I will present my parameters :
Type, classification, size, length (of single item), quantity...
