MEP Modeler - edit the slope of a piping
alemanda
Hi all!
I recently bought the MEP Modeler.
I tried to draw a pipe for waste water with a slope of 1% and I was able to do it.
The question is: how to change the slope of the whole pipe route I've drawn before in order to match the given exit discharge height?
Is it possible?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
5 REPLIES 5
I don't know the answer, I have not worked with MEP Modeler enough to know the answer.
Here is an MEP Modeler playlist on YouTube, hopefully one of the clips will contain the answer:
https://www.youtube.com/playlist?list=PL40B6E31580FD53EC
alemanda
Thanks Laszlo,
Plan route Editing seems to be very easy.
While I understood how to draw the pipe with a slope, I didn't find the way to change slope of piping at once. Rather it seems that I should change the slope piece by piece ...
Does Anyone else have a suggestion?
I want to say also that the concept behind the MEP modeler would allow archicad to be also a very powerful structural modeler ... smart connection between parts could be extended to structural connection
AC27 latest hotfix
Win 10 Pro 64bit
I have received the info from GRAPHISOFT that after placement, you can edit the sloping of individual elements only, but not the whole network of elements.
alemanda
Thank you Laszlo.
That's a pity.
Hope they will implement such as pipe editing option in the next version.
AC27 latest hotfix
Win 10 Pro 64bit
furtonb
I've just started modelling a small house, this was almost the first issue I encountered - adjusting inclination for multiple elements is much needed. Probably it would be contextual: so the selected elements are affected only, the elevation change should be also indicated as % (or degrees).
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
