MEP modeler - labels
alemanda
Where are the specific MEP labels? I cannot find them in the library ...
Is it possible to label the MEP parts with the out-of-box- Archicad Labels?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Well... everything is possible. But not quite you expect.
If you are under 21 you can use the automatic text in the text label, but it will also not able to show everything, like GDL parameters
You can use the IFC label but first you have to create matching IFC parameters for the GDL parameters.
I have made an MEP label with a lots of feature, there is free version also. Use that one. aclabels.net
alemanda
thank you very much. I'll give it a look
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
gpowless
MEP Label for Archicad
http://aclabels.net/index.php/products/mep-label-for-archicad?i=1
This is well worth the $5.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
