Master layout info missing in AutoCAD’s Paper Space
After publishing a DWG file from PM 3.0
When opening the DWG file in AutoCAD’s Paper Space, I am missing all the title block information that comes from the master layout.
If I copy the title block from the master into the layout, and publishing again to DWG, the title block information shows in AutoCAD’s Paper Space!
Any ideas why that is?
7 Replies 7
Djordje
What information?
Autotext? Logos?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
everything that comes from the master layout: text, lines, autotext, logo..
Djordje
Hmmm ...
Did you patch the 8.0?
Why are you not on 8.1? It's free.
Djordje
HP Omen
I don’t think the problem has anything to do with AC, I’ve just tried with only lines drawn in PM 3.0 on a layout and again the DWG published only shows these lines drawn on the layout but doesn’t show anything coming from the master layout.
Does the patch update PM 3.0 also?
The most current release is PM 3.1 R2...Lose AC8.0 & PM3.0....then we can all forget that they ever existed!
Djordje
EXACTLY my point!
It is FREE
Djordje
HP Omen
I asked Graphisoft Technical Support about this.
There was such a problem in earlier versions but it got fixed a long time ago. You should upgrade to AC 8.1/PM 3.1 (free) and it will work.
Laszlo
