Maxonform to C4D help me to clarify
Hi there , iam using maxonform along archicad 11 , and i have a very usefull
tool in my own architectural practice , but i feel insecure about , update maxonform to C4D , because iam affraid ill loose all ,or almost the major organic tools capabilities tha maxonform offers , as C4D is a rendering software and have some different kind of packages , i understand ill have to use architectural edition of course , but i would like to know if this version contains all this organic capabylities that maxon already has .
thanks for help
You will only gain by the change. C4D is not a rendering software, as some here may have led you to believe. MaxonForm was just a stripped down version of C4D, containing just its modeling capabilities (or at least most of them). So, C4D is everything you had in MaxonForm and much, much more.
If you do not want the 'advanced render' capabilities of C4D, but are just focused on modeling, then just obtain the base C4D package.
Hi Karl, thank you very much for the info , it has been very usefull to me .
