Maxonform vs. form z
Naturally I would expect a more maxonform-pro environment here, but nevertheless...how does it compare with form z? i have never used either product, and am just getting my feet wet w/ archicad 10. any input?
1 REPLY 1
David Larrew
From my limited knowledge of both packages, I can shed some light on generalizations...
FormZ - Great 3D modelling tool. To use with AC you will need to export/import the geometry between softwares.
MaxonForm - Specialized version of Cinema 4D (see below) made to work with AC through the MaxonForm plug-in. Letting you work seamlessly (to a point) between the two softwares.
Cinema 4D - Great 3D modelling/rendering/animation tool.
As with any software package, each software has their pros and cons. In the end it is up to user preference.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
