Merging AC9 project to AC10
Where can I find the proper method and steps to bring an old AC9 project and layout book into AC10? We typically have two model files; 1 site, 1 building and then one layoutbook. Can these be combined into one file?
4 Replies 4
TomWaltz
It's in the "New Features" PDF that's in your Archicad 10 installation folder. The easiest way to it is through the Help menu in AC10.
Tom Waltz
The main issues are:
1. Open and save the layout book as an AC10 file before merging it into the building model (PLN, PLP).
2. If you have been using PMKs instead of direct links to the PLN, relink them in PlotMaker before converting them to an AC10 file.
3. Do not rename the project file (PLN) before merging the layouts. This will prevent the drawings from automatically linking to their associated views. You can either Save As after the merge, or archive the AC9 files before starting the conversion (preferred).
The below link is also a useful one:
http://www.archicadwiki.com/Archicad_10/Project_Migration
Thanks Laszlo, thats a great resource.
