Rick Thompson
Missing List Schemes in 19
I am looking for conformation on this being my issue, or a bug. Over many years I have moved my "Property Data 65" with all my property objects, data base, and list schemes from the older library, to the newest one. I guess I have not needed to generate a material list in 19, but now that I need to, I am having to back save to 18 to run it. In 19, my property objects show up, but none of the schemes. If I load the older 18 library set-up, it's fine (except I am then missing all the converted objects, which need to be listed. But, the same set-up with the 19 library has the schemes missing. I tried taking the "List Templates 19" out to eliminate conflict (but, that's not an issue in 18), but no change. Anyone else have this experience?
thanks
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
2 Replies 2
I checked it and I have these folders in the ARCHICAD 19 Library, just like in previous versions. See attached image.
Rick Thompson
I have those too, and they show up. It's the prior one I developed that I use, and manually transfer to the new library, that don't show up. In past I have removed the new folder and replaced it. But, this round that doesn't seem to do the trick. thanks for looking
Rick Thompson
Mac Sonoma AC 26
