yesterday
- last edited
yesterday
I have modeled a window, but when I export the IFC, I get the surface name instead of the building material name. I need the building material name; how can this be resolved?
Thank you to everyone
yesterday
Can you give some more info about this (along with screenshots if possible)?
What is the current result that you are getting?
What is the exact Window parameter you want to see exported to the IFC file?
What is the exact IFC Property where you want to see this information exported into?
yesterday - last edited yesterday
Hi @marcocioeta
As far as I know, Archicad's default windows do not have a building material as such; instead, they have surfaces for several parts, depending on the library object. Anyway one of these options could help:
9 hours ago - last edited 8 hours ago by Barry Kelly
The current result is the first image attached;
the exact parameter I would, it is the building materal;
the exact IFC Property issuch as the second image, the name of the IFC Material
