Numbering in schedules
how i should put numbering in ascending?
In schedules numbers are located I would not like 1, 10, 2, 20
6 REPLIES 6
If the numbers are part of you element's ID then try typing 01, 02, 03, ... 10, 11,... etc.
And 001, 002, 003, ... 100, 101... if you need to list past 100.
i use zone tools. Trying to put zone number in ascending order.
Yours recommendation
If the numbers are part of you element's ID then try typing 01,02, etc.
And 001, 002
Don't help at all
Interesting - it does for me (tested in version 12).
And without the "0" prefix.
It even works with an underscore.
oh thanks, i get it
I make a mistake, put zero to all numbers.
