Object elevation on schedules
I'm wondering if it is possible to get a perpendicular view to a surface in a schedule for object or curtain walls similar to the elevation for windows? I have created an inclined curtain wall as a glass roof.
As far as I see there are no such Schedule Fields available for Curtain Walls.
As a work-around I have copied the the curtain walls and set them to 90 degrees standing elements and adjusted the height to the diagonal of the inclined curtain wall and used a normal elevation.
