2023-02-22 05:58 PM - last edited a month ago by Molinda Prey
Trying to open a dwg file in archicad but get the message "No elements were created", and nothing showes up, neither in the 2d or the 3d window...
Is there a way of fixing the problem? (Or maybe another file format to choose from autocad which is compatible with archicad?)
2023-02-27 06:10 AM
How are you trying to open the DWG file? Using the Open command?
You can try placing a Drawing, then selecting the DWG file as its source. Does it bring the DWG file then?
