Openings in Curtain Walls
Scott Bulmer
To the Tower an Hour club;
In anticipation of the upcoming curtain wall system, what is (will be) the best way to schedule and/or reference openings within that system?
Just trying to do a little forward planning.
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
6 REPLIES 6
Does it mean a Door or Window in a Curtain Wall can not be referenced with a Marker & then Scheduled?
Any one with AC12 can give a fed back?
Thanks,
joseph
I think, you can make a list of elements, where the criteria is selected to element type, and the value is set to curtain wall panel and, door.
It makes sense.... but we will have to wait and see.
Cheers!
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
kevin b
So it doesn't appear that you can add a marker reference for curtain wall doors . What are other people doing about this?
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
Erika Epstein
Other than having tantrums?:lol:
Graphisoft does know about this.
The doors can be given individual IDs for scheduling. So what's left is faking the graphic of the door marker. The label tool, set to the door marker of your choice can be manually placed. Not nice or live, but works for now. Once the first one's parameters are set up if you have it read the ID you can quickly copy it around the plan. Change IDs in the info box as you go or use the element ID manager to do it for you.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
It doesn't appear that this has been addressed in V13, or am I missing something?
If not, Erika's solution appears to be the best way to schedule this.
Thanks,
Tom Krowka
Any other way to do this. Also, so the info can show up in the door schedule.
Thanks tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
