Lukas Zeleny
Option Set in Property manager - Allow mutiple choices
It can be a feature but for me it is a bug. You can no more use Property in Expresions when you change settings of Option Set in Property manager to "Allow multiple choices". It would be useful to still have this option when you want to combine more parameters in to new one in schedules or labels.
BIM Manager at SIEBERT+TALAŠ
www.sieberttalas.com
3 Replies 3
Here is my question:
When you set the Options Setup Dialog to "Multiple Choices", then if you use the Fire Resistance Rating in the Expression defining the "xxxx" Property, then how should Archicad decide which of the multiple choices you allowed for Fire Resistance Rating should be used when calculating the value of the "xxxx" Property?
Lukas Zeleny
It is usefull when you want simply lis all of the selected options in one label, for example Building objects combined by "concat" in to one parameter with another atributes
gdford
Apparently the multi-choice option removes the ability for the option set to be available in expressions. This is a real shame.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
