Mats_Knutsson
Mentor
Our dwg's bog down Revit and Autocad...
We're working with a MEP consultant that is using our dwgs+IFC. They experience that dwg from Archicad lately make panning and zooming in revit (and acad) slow and jerky. They have noticed this in several projects when the architect is using Archicad (revit-generated dwgs work much better). The MEP-guy  thinks it has to to with text elements. However when they look at the text properties they look exactly the same as those the MEP is using.
Anyone that have a clue/idea/solution?
Br,
Mats
AC 25 SWE Full
6 Replies 6
Perhaps the fills?
Vectorial Fills works well with dwg when symbol fills works well with PDF, but the inverse is not true.
Archicad 27 - GDL - PYTHON
Aaron Bourgoin
saw this post by the Enzyme team as their response to the problem. Looked relevant to your question. I need to look at this further.
https://blog.weareenzyme.com/improving-2d-cad-from-bim-automating-batch-process-of-dwgs-using-grassh...
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Mats_Knutsson
Mentor
No. fills are forbidden since decades 🙂
AC 25 SWE Full
Mats_Knutsson
Mentor
Hmmm...should we have to do this ourselves? I'll ask GS.
Our Pythoners and Grasshoppers are developing edgy things...;)
I'll investigat what versions af Archicad that caused this because it's a fairly new issue.
AC 25 SWE Full
Erik Bjornhage
Did you figure out which version of Archicad it is that causes the problem?
/ Erik
Erik Bjornhage : SwedishChef, INSIKT Digital Sapiens, Gothenburg, Sweden - Architect : Digital Development : Graphisoft Cert. BIM-Manager - Eriks LinkedIn : INSIKT
ThinkPad P1 G7; Ultra9 185H; 64 GB; RTX 4070 [8GB] : AC12 - future
Mats_Knutsson
Mentor
Must be 23.
AC 25 SWE Full
