Hi Paul,
Thank you for sharing the issue and I am sorry about the experience!
With a blank template file, I was unable to replicate this issue. There are a few things that I would like to check:
- Which ARCHICAD version are you using? Please make sure that you are using the latest update (AC23 update 1 and AC22 update 4 have been released recently)
- Try to open the PDF using another PDF reader, or another machine/screen to see if the PDF is displayed correctly
- Try to publish to PDF from another machine
If you still haven't been able to get a correct result from the tests above, I suggest creating a new file from a blank template to see if the issue persists. If we see a correct result from this export, that means there must be something wrong with the current file that you are working on. If that's the case, I may need to have a look at your file to see what is causing the issue.
Best regards,
Minh
	Minh Nguyen
Technical Support Engineer
GRAPHISOFT
