2006-10-05 06:27 PM
2006-10-06 01:51 PM
Geoff wrote:Did you try printing it to PDF again?
The Seattle Department of Planning and Development plan coversheet is available as an Arch D (24"x36") PDF with interactive form fields. This is a great convenience. Trouble is I cannot figure out how to get the form data to show in ArchiCAD. I have the form all filled out and looking good in Acrobat, but when the PDF is placed on an ArchiCAD layout all the fields appear empty. I have tried saves and save-as's to no avail and cannot find any kind of "flatten" or "bind" type of command. Anyone had any luck with this? Thanks.
2006-10-06 05:23 PM
2006-10-06 10:58 PM
Geoff wrote:Geoff, since you're on the Mac, I don't know if this works with your document, but in similar situations I've saved the PDF from Acrobat and then opened it in OSX's Preview and THEN Print>Preview>Save as pdf. This is also sometimes works as a workaround when the Crop command in Acrobat won't let you really crop to reduce content of a pdf.
I thought of that. But Acrobat does not allow printing to PDF (or previewing), at least on Mac. You get the dialog below, which puts me back at square one.
2006-10-07 12:08 AM
2006-10-07 01:31 PM
2006-10-09 11:27 PM
2006-10-30 03:28 AM
2006-10-30 03:38 AM
2006-10-30 03:57 AM
