We value your input!
PLN viewer on mobile devices
Electric Flute
BIMx is cool but...
If I want to view my plan on the construction site to check just a detail??
Please, don't tell me to convert my model to BIMx every day. I also need a PLN viewer on mobile devices!
AC26 > AC5 - Win10
5 REPLIES 5
I think you can just upload the new layouts where those new details are created on a day to day basis without having to republish the entire set or model.
Or have a PDF viewer for your device?
Electric wrote:
BIMx is cool but...
vistasp
Get a Windows tablet and run ARCHICAD in demo mode?
Publishing a BIMx model can be a one-click affair after it is set up.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Electric Flute
AutoCAD (DWG file) - AutoCAD 360 by Autodesk
Sketchup (SKP file) - SketchUp Mobile Viewer by Trumble
Revit (RVT file) - A360 or Buzzsaw by Autodesk
Vectorworks (VWX file)- Vectorworks Nomad by Nemetschek
ArchiCAD (PLN file) - No option
Am I the only one who needs a mobile viewer?
AC26 > AC5 - Win10
Electric Flute
A360 and Buzzsaw are subscription services that can run to thousands of dollars per month depending on your usage.
A simple method I use is to just connect to my desktop via Remote Desktop connection and run ARCHICAD on my PC, I have been doing this for a few years from my ipad2 via a 3G connection with no issues and am sure that the file I am viewing or editing is current.
I have also connected from my iPhone when I haven't had my iPad just to check a dimension but the screen really is too small to be of much use.
Scott
Electric Flute
Interesting workaround, thanks.
AC26 > AC5 - Win10
