PT
PROBLEM WITH DOOR & WINDOW BUILDER IN 3D
How do I get rid of the diagonal hatch (fill) on the 3d view of this door.
(Its a door with a big sidelite on one of the sides) Ive tried to uncheck the
use object materials on the model tab on the door selections settings, this usually works, but as soon as I try to extend the door with a sidelite it covers the door with this horrible hatch. Please help
3 Replies 3
I've used D&WB for three years now and never seen that before. Weird.
Is it something to do with material (with associated fill pattern) assigned to door "frame and glass" or "door leaf" in the materials tab? Does the fill go away when you remove the sidelight?
Puzzling....
Thomas Holm
Isn't that the mosquito net?
that was it! Thank you very much. I was going nuts trying to get rid of this fill. !
