Pen Conversion...
I have a plotmaker layout book that has drawings in it that have various different pen thicknesses... When I publish to DWG and send it to a collegue using AutoCad 2000.... he sees much thicker lines.
I know almost nothing about Autocad, he knows nothing about ArchiCAD..
Can anyone point me to a resource that would help me sort this out... Im sure I just need to make translator changes...
Plotmaker 3.1 to Autocad 2000
Ben Odonnell
Nefarious,
If you simply change your line thickness, from true weight -----> Hairlines, under your display options in Plotmaker, it will give you hairlines even in AutoCAD.
See attached image.
HTH.
Cheers.
Ben
Ben O'Donnell
I know about that one, but I have a few pens I want to be slightly thicker than hairlines.
any help would be greatly appreciated.
Always send hairlines to an AutoCAD user. Otherwise he ends up with a mess (difficult to edit polylines). Set up a protocal so he knows which pens need to have different weights and let him set up the weights himself.
woodster
