Pen Sets & Excel
Is there a way to get the pen set settings into excel? I am looking for a way to see the pen set number, colour and line weight in a table format. Or perhaps someone has a chart made up of the standard pen sets.
KrisM
David Maudlin
Kris:
Yes, via Attribute Manager. In Attribute Manager select the Pens & Colors option, click the Select All button, then Print to File... at the bottom of the dialog box, this will create a tab delimited txt file that can be opened in Excel. This can also be done in AC22, but the procedure is a little bit different as the Attribute Manager dialog box has been redesigned.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
David Maudlin
Kris:
Great. That's easy. Thanks.
Kris
