Kris:
Yes, via Attribute Manager. In Attribute Manager select the Pens & Colors option, click the Select All button, then Print to File... at the bottom of the dialog box, this will create a tab delimited txt file that can be opened in Excel. This can also be done in AC22, but the procedure is a little bit different as the Attribute Manager dialog box has been redesigned.
