Pens & Colors method for dwg translation?....
I have not fooled around with this part of the translation setup much. Alot of people I work with uses AutoCAD 2005...
Which setting do you recommend is the "least troublesome" for AutoCAD users with regards to methods under the Pens and Colors portion?
Thanks for any suggestions or tips..
Note: the 'RGB' selection happened to be the selected default when I created a new translator....
1 Reply 1
We use a variation of the Keep Pen Index Number. We have a few things that change in other areas. I have had some problems where it takes a while to create the DWG, or it freezes up. Probably someone made an adjustment somewhere they werent suppose to because I can reinstall a backed up one and not have any issues.
