Pens
Red
Is there anyway to print out or export the entire pens & colors list and pen weights to a spread sheet?
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
4 REPLIES 4
Under the attribute manager - select the pens tab and click the "Print to File" button. This will then export a .txt file which can be opened in a spreadsheet format (Excel) as a "tab" delimited file.
Good luck,
Red
Thanks for the help.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Hello Red,
Another solution could be to make a SQL-query, for example;
SELECT ID, WIDTH, COLOR_RED, COLOR_GREEN, COLOR_BLUE FROM PENS
ORDER BY WIDTH DESC, ID ASC
this way the info comes out readily sorted.
Juha
