PlotMaker--->Publisher--->DWG--->Archicad---->??
I have published a drawing from PlotMaker on a .DWG file format.
I have tried to open this file within Archicad for a final check and mark-up notes but there were no lines visible whatsoever.The drawing vanished...
What am I doing wrong?
Jaime Neto
PowerBook G4, 1,5 Ghz, 1Gb DDR SRam, MacOSX 10.3.9
Archicad 9/ PlotMaker 9
4 Replies 4
Maybe you saved from PlotMaker into Paperspace in the DWG file, but when you opened it in ArchiCAD you set the translator to import the modelspace. Just guessing.
You can try to open it with edrawings free dwg viewer for mac downloadable here.
try using model space in the translator
After a certain amount of trial and error experiences, I understand now that if you want to check a published Plotmaker DWG drawing within Archicad, you have to do the following:
1. Publish the DWG drawing from Plotmaker using the option "model space with cropped drawing's content";
2. Opening on Archicad using the default translator.
Thank you all for your insights.
Jaime Neto
Archicad 9.0 / MacOSX, Powerbook G4
