Problem with IFC Add-on Installation
Michael
in trying to add 2x2 add-on and 2x3 add-on two problems arose
One: there is no IFC dialog under File Special, which exist previously
Two: there is a error message under Options>Add-on manager
See attached picts.
Any suggestions
undefined
Michael |:-)
AC 4.5 - 19 Build 3003 Full USA
Mac OSX 10.10
4 REPLIES 4
Michael
See attached picts.
Any suggestions
undefined
Michael |:-)
Mac OSX 10.10
Michael
See issue described in Installation part of forum thanks
PostPosted: Thu Apr 03, 2008 9:55 am Post subject: IFC Add-on Installation
Michael
Michael |:-)
Mac OSX 10.10
Hi Michael,
Both messages were in the wrong forums. I've moved and merged.
You will not see the commands in the menu until the add-ons are recognized. The add-on manager error suggests that you don't have the correct versions installed (or have multiple versions). Make sure all hotfixed are applied to your copy of ArchiCAD and download again?
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Michael
Thanks for the suggestion Karl, sounds correct.
The current version is loaded at Build 1010, there are three subsequent hotfixes online.
The latest hotfix will not load, once downloaded to the local machine.
There is no apparent way to load the others.
stumped again
Michael
AC 10 : Intel
javascript:emoticon(':cry:')
Michael |:-)
Mac OSX 10.10
