Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Property Manager_create new properties
[list=]I would like to create a new property group listing the name of occupants and the rooms they occupy.
[list=]I have created the group named coordination --> inside this I will have the new property called occupants.
  • HOW DO I ASSIGN A PERSON TO A ROOM? Please....
  • 11 REPLIES 11
    Laszlo --> ok for the Air Con .
    Basically need to add semi colon NOT commars between textes.
    However, is it normal i must choose TRUE or FALSE ??
    Idea is the IF rule should set this rule right ? Not for me to choose if true or false.
    --> If you could expand on the other point concerning occupants and zones a bit more that would be appreciated. See my question above -- HOW TO ASSIGN NAMES LISTED TO ZONES ?
    So what property available for the zone do i use, in order to assign a person to that zone ?
    I have alist of 4 rooms and 4 persons. One person needs to be assigned to each.
