Publish in PM to DWG; Locate txt.SHX
When publishing a Set of views as DWG from within Plotmaker each sheet is asking for me to Locate txt.SHX. I am selecting Skip all. SHX shape files are created along with each sheet.
Do I need to send each of these SHX files to the out of office consultant? Also they are using AUTOCad 2000.
Should I set up a translator so that I can Avoid this creation of SHX files? And the interuption as each sheet is created?
0 Replies 0
