Publisher Set
I am a new AC10 user on Mac PowerBook G4 (OS 10.3.9).
I am trying to create a Publisher Set in PDF or DWG format that I can e-mail to my consultants. In the Organizer window I drag a layout sheet from the Layout Book to the Publisher Set. Then I click on the 'Publish' button at the bottom of the Navigator.
A Publisher Set Properties window pops up. I select the Save Files for the Publishing Method. Then I click the 'Browse' button to select the folder in which to save the Publisher set. Then I select the 'Create flat file structure' and click OK.
Then I highlight the recently transferred file in the Publisher Set and click on 'Publish' button at the bottom of the Navigator. A Publishing window pops up top show the file being save to the destination folder. It also show the size of this file.
Finally when I try to open this file in Adobe Reader (7.0.5) and an error message pops up - " ....not a supported file type or because the file has been damaged..." When file icon is highlighted it shows the file size to be zero. I get the same result no matter which Layout with content I save to the Publisher Set.
I also tried this in DWG format. I was able to open the Publisher file AC10 but it was empty.
I got the same results when I tried after restarting the computer.
Appreciate if anyone have a solution to this problem.
14 Replies 14
Marc:
I went to Application>Utilities>Java folder. I did not see a software update either in Utilities or Java folder. I saw in Java folder 1) Java 1.3.1. Plugin Settings and 2) Java 1.4.2. Plugin Settings.
I am beginning to get discouraged.
Bala
Stress Co_
What happens if you open "System Preferences" ( it may be in your dock or in the applications folder) select "Software Update". Is the java update listed when you "check now"?
Marc Corney, Architect
Red Canoe Architecture, P. A.
Marc:
I did check in System Preference for Software Update before. When I clicked on the radio button for Check Now only QuickTime showed up.
I think part of my problem is my OS 10.3.9 which I plan to upgrade with a new computer soon. I have also shared this problem with Tech Support. I will let you know of their response.
Bala
Stress Co_
Bala:
You should be able to create PDF's from Publisher by "Printing"> save as PDF from "print settings" (in lieu of "Saving File" as PDFs). But multi-page PDFs will only save the last page. You have to save/(print) a sheet at a time. That make any Sense?
Marc:
If under Published Method I select 'Print' instead of 'Save File' then go to 'Print Setting' at the bottom of the Navigator-Publisher Set window I am able to save this as a PDF file. However when I try to open it (a procedure I follow to make sure the file is O.K.) I get an error message. Tried this several time and got the same result.
I find the desired result can be achieved if with the active sheet in the Layout Book is selected the go to File>Print>Save As PDF to a folder. I have done this with plan file before and it does work. I just found out it works with Layout file as well. But this is a time consuming process and I hope Tech Support has a solution that I can use in my current OS 10.3.9.
Bala
