‎2019-06-06 10:48 AM
‎2019-06-06 10:58 AM
‎2019-06-06 11:06 AM
‎2019-06-06 11:16 AM
thinhphamkts wrote:In AC22, you can multi-select attributes, and use Delete and Replace on the whole selection. Then check the report to see how these attributes are used from the selected attributes. In AC21 (and before), you have to do this one by one for Surfaces from the Surface Settings.
This means I have to delete manually, is it true?
‎2019-06-06 01:27 PM
