RECONNECT AUTOTEXT LABELS ACROSS STORIES
gdford
If i have an object that extends into multiple stories and I pull data out of the object in story 1 with a label, and then i copy and paste this label from story one to story two, is there anyway to reconnect the label to the object. I know I can recreate the label for scratch, but i have lots of labels and the problem is the same in section and elevation.
Does anyone have thoughts on this?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
4 REPLIES 4
Eduardo Rolon
in AC21 if I am not mistaken when you copy/paste a Label with the label selected you can Opt? (MacOS is CMD) click to a new element and it will associate with it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
I believe in Windows it is select the label then CTRL-click on the element you want to associate it to.
I don't have Archicad in front of me at the moment but I am pretty sure that is correct.
gdford
Barry - you were correct! - I never thought to try that.
Thanks - that's going in the database!!
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
That is a good tip and one that I was not aware of.
