Relink Accessory Objects
Hi all!
does anyone know if it is possible to relink an accessory object with a slab/wall/roof when it has been detached?
Btw if you know also why they sometimes get detached without an obvious reason I'd be happy to hear that.
Olivier
Cosminn
Not sure if an object can be relink after he has been detached from an element. but i know if you link more then 2 objects with an ArchiCad element such as wall/roof/slab, when you'll link the third one, one of the 3 objects who are linked will loose the link. If make sense...
And so on, if you'll place more then 2 objects.
i noticed that 2 objects are fine, works fine.
Now this is not going to happen if you'll use the Cadimage accessory tool.
Try It!
Sincerely,
Daniel
It occasionally does happen with Cadimage coverings too, but I've found that going to Cadimage> Coverings> Update Coverings usually fixes things.
