!Restored: Cinema 4D plugins for AC11
anybody can tell me where can i obtain the plugins for Cinema 4D 10.5 for work with Archicad 11 ? also where is the correct place (i mean folders) to put these plugins ?
thank you in advance
12 Replies 12
yes, it is appearing in ArchiCAD(design>design extras). That is what i need, to add cinama's file format in save as dialog in ArchiCAD!!
I've installed both plugins from http://www.graphisoft.com/products/archicad/solutions/cinema4d_download.html
Is there something more that i need to install? Btw, i don't have any archicad folder in my Exchange Plugins.
owen
Those are the Maxonform plugins.
The Architecture Exchange plugin installer can only be found on the CD you get with Cinema4D as part of the Architecture Bundle (C4D+Advanced Render+Sketch & Toon). I'm not sure if you can buy the Exchange plugin separately if you already own C4D .. depends on your reseller
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Try this free solution.
