!Restored: how to open 3ds file in archicad 9
i am trying to import 3ds file in to archicad 9 .. how can i import ? any body know about this,,, pls help meee
Thomas Holm
You need an Add-on, a plugin, to import 3DS files. Later versions are found under Goodies in the Help menu, but for AC9 and previous, I think you'll have to talk to your reseller to get it.
Here's another way to do this:
1)Download a free SketchUp program (if you don't already have one).
http://www.google.com/sketchup/download/
2)Download SketchUp import Add-On for ArchiCAD v9
http://www.graphisoft.com/products/archicad/solutions/su_plugin_download.html
3) IMPORT (not open) your .3ds file in SketchUp and save as a SketchUp file (You may need to archive it to an earlier version for ArchiCAD 9).
4) Open the SketchUp file in ArchiCAD 9; you'll get a window that tells you what to do & pretty much takes it from there for you. It can be a long process, depending on how large your .3ds file is, but this should then convert everything so that you can then work with it as an ArchiCAD 9 file.
Hope this helps,
T
