Revit Conversion to ArchiCAD
Hello, my architectural firm is going to be taking over a project that was drawn in Revit. The project is nearly complete, it is just missing construction documentation. I’ve been researching file conversion from Revit to ifc to ArchiCAD, but wanted to get your opinion on the matter. Is it possible to make this conversion while maintaining most of the projects information, or would I need to re-draw the entire project? Thank you.
-Nathan D.
Western US reseller BIM6x has made this conversion add on available at no charge:
https://bim6x.com/RFA-RVT-Add-On-FAQ
One of the forum moderators
Thanks Karl
