fuzzytnth3
Rooflights
Is it possible to list rooflights in the Window Schedule?
Or do I use the object schedule to list the rooflights?
TIA
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
3 Replies 3
They are not windows, so filtering on "window" will not select them.
Yes, object. Use special ID's for them so that you can add another filter by ID prefix or suffix to obtain just the rooflights (skylights).
fuzzytnth3
Thanks for confirming that.
It's the first time I've used the new schedule tool since upgrading to AC 9 and found it wee bit hard to get the hang of it initially but I've got what I want.
The only thing I don't understand are the formatting controls which if you put different numbers in from the default they don't seem to make any difference to the finished schedule which is a bit weird
Post some screenshots so we can help? (to a new thread)
