SAF compatibility
Ahmed_K
In my country, structure engineers uses autocad / revit for strucural drawing, and autodesk robot for analysis,
An engeneer asked me if there is a connection between Archicad and robot, so i can transfer the saf format to him for analysis
Thanks
Archicad 27
Windows 11 professional
5 REPLIES 5
ispyridis
Dell Precision 64GB RAM NVidia A5500, Wacom Mobile Studio 16 AC12-28, WIN
Interesting, and how is it ?
Do you faced some incompatibility of some shapes, transfer problems ?
Do you have any advice for modelling in Archicad to have a good SAF file for robot ?
Thaanks
Archicad 27
That's SAT with a "T", not SAF, with an "F" 😉
@Ahmed_KLook at the official website.
Robot has no native support for SAF. There is a converter, but even then Robot can only import as per today, not export.
So, no roundtrips for you...
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
ispyridis
runxel is correct I tried to edit the posts and delete these images. I found two links. about the .str file that is text file so someone could export from excel to this type of file using a macro. Read the following article from Tekla,
 Export a model to Autodesk Robot Structural Analysis | Tekla User Assistance
and the syntax of the file but in older version
R97 Mod 01 | PDF (scribd.com)
ispyridis
Also the SAF site that @runxel cited has converter for Dlubal and Robot.
SAF converter (structuraltoolkit.com)
