SURFACE schedule Excel export??
It seems you cannot export a surface schedule to excel? Only Elements schedules are available in the export dialog
Properties/informations are linked to an element by its classification. That's why you had to do a element scheldule to make an interroperability between excel (or others) and Archicad. But if you don't want an interoperability so you just had to do "save as" from your schedule and choose xls export
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
Christophe - FRANCE
Christophe wrote:
ah thanks for clarifying that! Its difficult to think that "save as" would actually save the schedule and not the whole project.
In this case, I must specify that according to each point of view, the command "save as" always offers a panel of different file formats.
Example: to export 3D you had to be 3D view to "unlock" some file extensions
Christophe - FRANCE
