Saving files in V10 from a Mac on a W2003 SBS server.
We are experiencing problems when saving files from a MacPro (2x2,66 Xeon Intel/3 GB RAM) running OSX (10.4.8 ) on a W2003 SBS fileserver. When it saves it makes a new filename and a new copy of the file.
Have anyone had this problem?
4 Replies 4
Thomas Holm
Guess: permissions problem on the server. Such problems are often mentioned, sometimes with solutions on the site
http://www.macwindows.com/
that has been controlled.
The problem only occurs from archicad, no other files from this user.
Thomas Holm
Ok. Apparently Archicad thinks the file that it has opened is read-only, so when you select the Save command, it defaults to Save As. I you're working in Teamwork, try to isolate the problem by creating a Solo project (.pln file), save it to the server, open it remotely like you describe, and save again. If the same issue occurs again, it's not a Teamwork problem.
It might be a bug. I'd contact the reseller and ask for support.
Thank you!
Somehow I solved it. I upgraded everything on the server, reestablished the user, aso. Now it works.
