Schedule of objects placed on a Layout?
So simple, there has to be a way!
I want to create a schedule based on data from objects placed on individual layouts, not in the model. (you guessed it - a revision cloud object)
But search as I may I can not find a way...
...any clues you gurus?
10 Replies 10
Richard wrote:
If the content is the same on every Layout, is there an advantage to using a separate worksheet over just putting the stamp on the Master Layout?
Thanks, Richard. Yup, Master is more sensible in that case! I should have said 'if it is the same on all of the layouts where the stamp is used.' Placing a worksheet vs creating a different master lets a person use Drawing Manager to see where the worksheet is used - which is basically the schedule that the OP was looking for I think.
If the 'stamp' isn't a single object, but is a group of stuff - including placed images and drawings - then a worksheet is an easier / more flexible way to edit the bits and pieces short of making an actual object, I think.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
